Adding an extra 2 receivers | SatelliteGuys.US
you can do it with a dp quad and a dp - 34 switch, you have to make sure that you have two coax jumpers going from the lnbfs ports one and two going to the switchs sat ports one and two to match up. The other two ports on the quad can support receivers five and six while the switch will support 1 - 4.
IF you note Van said with a DP Quad, you didn' t say wether you had Legacy or Dish Pro equipment. Legacy Quads can't be used with Dish Pro switches.
E10 and Hawaii
622 arrived...No Smart Card?
