Adding Cable to the mix | SatelliteGuys.US
hedbert
SatelliteGuys Guru
135
Apple Valley, MN
I have 2 HD receivers. Both back feed to other TVs. Here is what I am looking to do. I would like to add my cable feed into the mix and feed it to all TVs. Is this possable? OR what are my options?
Cable signal is pretty strong and probably on the same channels your backfeed from the HD receivers resides.
Substitute the cable line for your OTA line.
Set the output of the agile modulators on the HD receivers to an empty cable channel (you'll have to change the agile modulators from air to cable).
Where is DTVPal DVR the "first-look" thread?
snow fade w/ current metro NY storm
