Adding Frequencies to a Bell receiver | SatelliteGuys.US
Jr.nicholson
Michigan
Just curious if anybody’s had any success adding additional frequencies to the Bell Receiver currently the bell receivers are only 91 and 82. We’re just wondering if anybody was able to get 110 119 or any other frequencies added to the Bell Receiver with using a WinGuard traveler auto seeking satellite roof mountain
The frequencies used on each satellite slot are pretty much the same 12.224-12.691GHz.
The show stopper with your idea is that your Bell receivers aren't authorized to receive DISH encrypted programming.
The Bell receiver firmware isn't going to direct the Trav'ler to seek out non-Bell satellites. You would need to use a conventional dish.
Yeah you can't activate a Bell Receiver to Dish and vice versa. The Receiver #'s are locked to each provider, and they wouldn't be able to activate a receiver that isn't in their database.
Atlhough the receivers are capable of receiver either signal, but of course Echostar and Nagrastar isn't going to allow that.
