Adding new 622-- how to activate? | SatelliteGuys.US
ctjr
155
I should have a new, in-box 622 awaiting me when I get home this evening. Got it from what looks to be a reputable guy on eBay.
When it arrives, do I merely connect it up (I'm swapping out from an older box, so the cables are already in place) and then place a call to Dish? It should come w/ a card, correct?
Thanks!
Before you even call, what old "box" did you have?
We need to know what type of dish you have installed. If you only have one single cable going to the room where the 622 is located you need to have Dish Pro Plus LNBs or a DPP44 switch to work with a single cable and a DP Separator.
015 Aquiring signal Error
External hard drive
