Adding sd receiver to swm | SatelliteGuys.US
Dozerman2009
3
Kentucky
I currently have a have one hd receiver setup in my living room but want the standard def receiver in my room and on the current setup there is one wire coming from the swm 5 lnb going to the 2 way splitter and only one input which is going to my eve what would I need to make my second receiver work
:welcome to Satelliteguys dozerman2009!
You need a four way splitter, which has to be swm compatible. The only sd receiver that is swm compatible is the D12.
Ok I have the d 12 so when I hookup the four way splitter coming off of the lab would it be output or input to the receiver
If you have a port open on the splitter just run a line from that port to the back of the rec. and repeat satellite setup and it will work
Sent from my iPhone using SatelliteGuys mobile app
Reactions: Tecnicoloco
That is correct,no need for a 4-way splitter when you have 1 port available in the 2-way splitter,more signal loss added to the system
Just take the cap/terminator of the 2-way splitter and connect your new line to your D12 DTV receiver
You guys are right, I misread the first post. If there is an open port on that splitter, connect the additional receiver there.
Where is the SWM power inserter? If it is behind the HD receiver, then the other port on the splitter is available for the D12.
You are aware that your SD receiver will only work for the next 2 years or so... if not, you should just screw the D12 and go HD.
Directv King Quest
Installation.
