adjusting C-band dish arc | SatelliteGuys.US
dunnsept
358
Central Meechigan
Ok, here's the thing.. I would like to try to get 55 west. When I move my dish to the east limit, I have a count of 4240, The eastern most sat I have currently setup is 83west. That resides at a count of 4550.
my setup goes approximately 25 counts per 2 degrees.
East limit gets me somewhere around 61 west.
BUT I have "tons" of room left on the west limit. C4 is the westernmost sat I have and from it to my west limit I have 250 counts or so leftover.
is there a way to sort of adjust the mount to get more of the left-over room from the west side over to the east side?
would it be loosening the actuator mount and re-positioning it?
I have a perfect 10 ready to mount and a primestar, but it's snowing today.. gonna be a while before I can get more poles sunk in the ground
thanks
That is what I do. I retract the Arm to it's Physical Limit, loosen the Clamp and slide the Arm until I find my western Most C Band Sat (AMC 8 for me). Slide the Arm a little below that, 1/4" or so, so I am not "bumping" the Limit. Then Program the Sats driving East.
I get 55.5 to 139 with 24" Arm on 10' Unimesh.
thanks.. wonder if it would make any difference that whoever installed my setup did so backwards.
My dish is setup linear east instead of linear west.. but functionally should be the same thing to adjust it...
and I'm OOOOOH SO CLOSE ;-)
When adjusting the arm itself make sure you keep the proper geometry (angles) where it don't put undue stress on the arm.
Your Arm should be on the West side of the Dish.
Pushing to the East and Retracting to the West
I know.. the dish was there when I bought the house.. it's setup backwards. but works so I never bothered to change it. seems to track OK so I've left it alone.
think it would make _that_ much difference? aside from actuator wear? I mean will it track the arc better ?
I guess if I'm going to change which portion of the arc it tracks, I can check into setting it up properly at the same time. would be time to take the actuator apart and lube it up too.
It does not change the accuracy of the tracking, just how far West you can go.
Unless you have to get the Eastern Atlantic Sats, I would set it up the correct way.
Advice for first FTA on Birdview/4DTV setup
grabbed a new dish
