Adjusting The Dish For HD Channels | SatelliteGuys.US
Robel
44
What would be the best way to adjust the dish for the HD signal? Horizontal, vertical or tilt?
I get mid 80's to mid 90's on the other two satellites but, only mid 60's on a clear day on the 101.
Set the skew (tilt) exactly as per the spec and leave it alone.
Make sure you have ZERO line of sight issues.
Next make sure your mount is true, plumb and level on all sides.
If the above is done correctly, then the elevation should be exactly per spec also.
Then only adjust the azimuth as needed, allowing a few seconds between each adjustment for the signal to level out. Use a marker to note where you started.
So, the tilt and the elevation should be fine..
It's the azimuth that needs adjustment.
Thanks guys, I appreciate it.
Anyone figure how to fix TS360 rapid clicking?
deal for existing customers?
