Advice on DVR options for new sub | SatelliteGuys.US
Phaetos
55
Here's what I got. A nice 42" HD Mits in the main room and a little 19" SD Magnavox in the bedroom. The Mag will be upgraded hopefully soon. This is what I want. DVR capability for both rooms, HD for both rooms without killing the bank. I thought the 942 seemed like the option that I needed right now. Dual tuners so I can watch 2 different programs on 2 tv's at once, record a show and playback to either tv, with HD out to both tuners. At least that is what I understood. Knowing this, can someone help clear the air here?
yes and no. The 942 will play "hd" shows to outputs but only has coax output for tv two, so you will not get HD in room 2. But nobody makes a box that does HD in two rooms....yet
Jon
Jon
I know I won't be getting true HD on the SD set, but the picture should be a little cleaner than SD anyway. At least it was on Voom.
921 recording fiasco
522 Caller-ID not working
