Advice to find best ku motorized system | SatelliteGuys.US
SkySurfer80
229
149
Tennessee
I bought a NPRM since I cant install a pole and looking for the best I can get. I would love the 1.2 meter and motor, but cant get myself to spend the money, I see the Geo 36" but it is really a 34" if you look at specs. I am learning about gain and such and was curious is there a chart or way to tell how much db gain it takes to see a difference and such meaning 36 gain compared to 40 is 90% so does that mean my signal quality levels will be 90% or any way to compare dishes based on gain on the specs.
Any reputable sites you suggest me buying a motorized dish? I would love a real 1 meter or 1.1 meter dish but cant seem to find anywhere that sells them. I know electorica is full of crap advertsing a 39" when its really 35"!
Any ideas?
I hear of 1 meter and 1.1 meter but dont know where to find them. I google all over!
A few members here have Primestar or Andrews dishes which are 1 or 1.1 meter but that is an irregular size. I also don't think an HH90 would drive a 1 meter or 1.1 meter dish. You'd need the HH120.
Ok. Im just trying to figure signal quality differences compared to the gain and the signal differences between all dish sizes.
Ideally you'd want a 1.2m to receive most of what's on Ku. But as you noted, a motor to handle that size of dish is expensive. I find a 90cm to be a good compromise. I am able to receive 85%-90% of what's out there.
Yeah. Thats why a good 1 meter would be awesom to me. Kind of in between. I see the 36 has a 39.6 gain compared to 43 for the 1.2 meter. I really dont know how big a difference is for the 3.4 gain. It sucks because you can get a 5 or 5.5 foot dish for fair cheaper than the 1.2 meter, but I dont think you can put a hh 120 on the 5 footer anywhere.
Any of you used multicom? I see they have nice looking dishes but cant tell if you can put a hh on them. I saw raven site. Thing is I am only wanting to use one cable to run and tie into the cable box outside of the home, I cant use an actuator since it would be another set of wires. I cant run cable inside the home. Just tying into an existing connection from outside.
If money was not an issue you can buy a complete motorized Ku system. Motorised satellite dishes. Raven 1.2m motorised satellite dish. Raven 1.8cm motorised satellite dish. Raven 2.4m motorised dish. UK
Like a 10' C-Band dish is recommended, a 1.2m (4') Ku dish is recommended. The best dish is the homemade kind. ;)
I built one with an old Primestar 1.2m and a modified C-Band dish mount a few years ago and another one two weeks ago.
The dish farm grows another one ;)
Very nice pics!
I had a similar issue. I did not want to run a motor control cable that far so the VBox is inside the shed under the dish with a short cable.
So would you recommend the 1 meter or 1.1 meter with hh motor setup? Are the lnbs good or do you think I could put a geosatpro spl on one of these dishes? Never heard about these setups but that 1 meter or 1.1 depending of cost looks like it would be perfect for me.
I recommended the 1.2M dish size. But bigger is better in this area so 1.1M would be my choice of the two. I'm not a fan of Ku motors. I've had lots of them.
Reactions: Comptech
Skysurfer80: There is excellent advice in this thread. Re-read the thread multiple times, then make a decision.
I have both a 1.2m and a couple 1m dishes. I prefer the 1.2m. But it's more about the extra fade margin you get in bad weather. With a 1.2m, I will still lose the hardest to receive station (NBC at 103W) in hard rain, but the signal comes back sooner once the weather improves.
If you can't justify a 1.2m with a compatible motor, then a 90 cm with its compatible motor is great too. But whatever you decide, it's an investment that should last many years.
Sent from my SM-G950W using the SatelliteGuys app!
Reactions: comfortably_numb
It doesn't show out of stock but it's pricey. I've heard that there is a cheaper source but I can't find it.
Also:
Yeah I want to find a legit at least 36. It says the geosat is 87.5cm accross. The price is good though.
Why does it take sooo much time to "rebuild" US NAVY website?
Who Read This Thread (Total Members: 5)
