AIM Meter Replacement Battery | SatelliteGuys.US
Go through trialithic.
Google the name on the back of the aim meter and order directly from them
Good point, thats the name I found when I looked it up on the SS website.
If thye don't have it, they will order it and drop it to you as well.
May be able to order from Trialithic as well, maybe.
My issues with my SatLook lite, I thought was battery issues, but after taking it to the battery people, they checked the battery, they said they can build me one for about $40 ... seeing it use it about 2 times a year, I declined.
Then we looked into it further and found that the battery I had was good and it was the unit itself ...
There went $200 that I shouldn't have spent ... may have used it a dozen times over the few years I had it.
Who Read This Thread (Total Members: 5)
