Hello. I'm a new user to this forum (please be gentle
I use my DirecTV receiver in my RV. I have an old Magnavox single LNB dish (with an indicator LED on it) along with my Sony SAT-55 receiver. This dish is mounted on a Winegard tripod with compass points around the base. Because I understand that the mast must be plumb and the tripod properly oriented north-south, it rarely takes me more than two minutes to aim my dish when we set up camp here it Texas. I've conned over a dozen friends into giving up their cable and getting DirecTV, have done all of their installations and had similar success in aiming their dishes.
I really stubbed my toe when we went to Wyoming on a trip. I tried two different times at two different places and couldn't get any channels. I did what I've always done - looked up the zip code on the receiver, used the azimuth and elevation to set up the first dish alignment and then used the LED on the LNB to find the limits of the signal for both azimuth and elevation, setting dish in the middle of each range and looking at the receiver to verify my signal strength. Here is what I saw:
1. All transponders under 24 were zero.
2. I only had even transponders above 24 and and saw 75-90% on those.
I thought that I might be on the wrong "bird" so I very carefully and slowly swung the dish 20 degrees on either side of the limit of the signal I was getting but the LED never registered another signal. I moved to the top of the elevation range and tried to swing the azimuth again 20 degrees. Still nothing.
I tried all of the other tricks that I know:
1. wired the dish directly to the satellite in on the receiver to eliminate the RV wiring.
2. unplugged the receiver for two minutes, powered on and tried re-aiming
3. metered my cable for open or short
4. Called DirecTV and had them reset my account.
None of it was any help. I gave up.
When I returned home, I was determined to figure out what was wrong. I figured that either the LNB or the receiver had gone bad on the trip. I set the dish up in my drive way and had 85-90% on all transponders in less than 45 seconds using the same techniques above. Reception is great on all channels.
So where did I go wrong in Wyoming? What facts didn't I provide that would help you to help me?
