All E* products comparison chart | SatelliteGuys.US
The first thing I checked in the table is wrong. The 811 does not have an RF Channel 3/4 Modulated Output, unless the datasheet is wrong. I hope to get my 811 on Monday.
Keith.
The table is fine IF you resize the window width like I stated.
I took the link from a java-script popup that didn't allow resizing because their table has a gap at the top if you don't adjust the width throwing the whole thing off by nealy 1 whole column.
I didn't think I was that vague. Anyway, I will submit the way it shows up on the site. (javascript pop-ups must be enabled)
If you click on the link below, then click on the link to the left that says 'COMPARE ALL' it will display correctly.
http://www.dishnetwork.com/content/products/receivers/standard/index.shtml
811 iWeather on 9500
HDTV move to 110
