All This From Relocating Receiver?? | SatelliteGuys.US
Sparky911
Rockford, Illinois
Moved DirecTV receiver to a different room this week. Now noticing a strange happening...even though my TV takes IR input for On/Off function, the thing is turning on when I turn the satellite on (even when out of IR range). The receiver is set up for RF input from the remote. How can the darned receiver turn the TV on?! I have checked every setting I can find on the receiver and on the TV. Help anyone??
Have you checked HDMI control under display settings/video, if on turn it off.
Just a hunch ...
But check to see if "HDMI control" is turned on under the "Display Settings" menu.
If so try turning it off ...
Sent from my LG-H932 using Tapatalk
I'm sure that's what it is. It might be called CEC control instead of HDMI.
Wireless Genies
