Also need help with 622? | SatelliteGuys.US
beliveauj
36
I bought a 622 and need help with dish setup.I am in a RV and have a Winegard Movin View satellite dome which is a Dish500 with a "SW42"switch.I also have a Dish 300 for the third satellite.I also sent for a DP34 switch.What else will I need and a how to would be great.Thanks Jim
if that winegard thing is the one I'm thinking about, it actually only points at one satellite at any time and the "SW42" tells it which one to point at.
Since the 622 is a dual tuner box, you will need two of them, one for each tuner.
Connecting a third satellite to such a setup will be quite difficult I expect. I don't know where to start.
Closed Captioning [cc]
HD locals is houston echoing...
