as long as the H25 has a USB port (I think it does) then yes it will work
per solid signal it will work with the H25
Works with the H25. (Will need to reset H25 after adding)
For the HR21/PRO HR22 R22 HR23 H24 HR24, HR34 and H25
I took a look at solid signal and see the note about it working with the H25, but it's noted on the new AM21N model. Maybe that is the true compatible version. The power cords/power inputs between the older AM21 and H25 are definitely 2 diferent shapes from what I'm seeing in all the manuals on line, so unless the USB overrides the power need, I don't think the AM21 power cord will connect to the H25. Have a chance to pick up the older model AM21 fairly cheap, but don't want to be stuck with it if the power cords are not compatible. Thanks again for all the information.
All previous receivers could be independently connected to AC power. The H25 is the only one that MUST be.you need to plug both in to the wall. This is the only model that I know of that does that
Am I going to be able to watch the local channels in Montreal (Canada) using this AM21N??
the others wont scan. ONLY the Genie scans
the rest work off a database
Limited time offer
