welcome
from another Twin Citian (I'm near Mystic Lake)
With the HR24 and AM21 you do not get the following channels as they are not in the database
5-3 MeTV
5-6 ThisTV
23-3 Country Network
29-3 Bounce TV
5-4 IS in the list (and has guide info) so you can see it
Both Mankato stations (KEYC 12 and Fox Mankato 12-2 are in the guide too)....I can pick them up just fine
What you do is in setup put in your "home" zip and the secondary will be 56001 (Kato)....it will load the channels in the list. Now note since the Minneapolis market is so huge (it actually runs from Iowa almost to the Canadian broder) it will load some stations that you wont get because they're in Alexandria, Brainerd and Bemidji. It gives you the option to remove the non receivable channels so they wont show in any guide. But here is the list of Mpls DMA stations that load (along with KEYC and KETC-DT2)
KTCADT 2.1
KTCADT2 2.2
KTCIDT3 2.3
KTCADT4 2.4
WCCODT 4.1
KSTPDT 5.1
KSTCDT 5.2
KSTCDT2 5.4
KSTPDT2 5.7
KCCODT 7.1 (satellite station of WCCO....based in Alex)
KAWEDT 9.1 (PBS in Bemidji...same as 22)
KMSPDT 9.1
KAWEDT2 9.2 (see above)
WFTCDT2 9.2
KAWEDT3 9.3 (see above)
KAWEDT4 9.4 (see above)
KAWEDT5 9.5 (see above)
KAWEDT6 9.6 (see above)
KWCMDT 10.1 (PBS in Appleton.....near Alexandria)
KWCMDT2 10.2 (see above)
KWCMDT3 10.3 (see above)
KWCMDT4 10.4 (see above)
KAREDT 11.1
KAREDT2 11.2
KCCWDT 12.1 (satellite of WCCO...based in Walker/Bemidji)
KTCIDT2 17.2 (this is actually 2-2 but since D* carries it on 17-2 it shows up)
KAWBDT 22.1 (satellite of KAWE...PBS in Brainerd)
KAWBDT2 22.2 (see above)
KAWBDT3 22.3 (see above)
KAWBDT4 22.4 (see above)
KAWBDT5 22.5 (see above)
KAWBDT6 22.6 (see above)
WUCWDT 23.1
KFTCDT 26.1 (satellite of WFTC 29..Bemidji)
WHWCDT 28.1 (Wisconsin PBS...based in Menomonie...near Eau Claire)
WHWCDT2 28.2 (see above)
WHWCDT3 28.3 (see above)
WFTCDT 29.1
KMSPDT2 29.2
KPXMDT 41.1
KPXMDT2 41.2
KPXMDT3 41.3
KPXMDT4 41.4
KSAXDT 42.1 (satellite of KSTP....based in Alex)
KRWFDT 43.1 (satellite of KSTP..based in Redwood Falls)...now there is a 43 in Mpls proper...its a low powered station of Home Shopping. Can be tuned but will have wrong guide info
