Well, aren't you a Debbie Downer today.
Hi All,
I guess SES has faith that 20 year old AMC 6 will be able to continue long past it’s retirement date which was 2015.
John
I agree.I sure hope they don't spot beam 139w that use to be great bird years ago.
That is not the reason for the move, but it is part of the narrative.There's a swap going on. AMC-6 is moving from 83 °W to 139 °W and AMC-18 will move from 139 °W to 83 °W. Apparently, SES wants to modify the footprint of the satellite at 139 °W to include more of northern Canada, but needs a different satellite than AMC-18 to do so.
AMC-6 will only be used for C-band at 139 °W and AMC-18 only has a C-band payload, so unless something else is moved to 83 °W, there won't be any Ku traffic there.
The narrative filed with the FCC - https://licensing.fcc.gov/myibfs/download.do?attachment_key=2411746
I guess I lose ARCS here in NM just in time for the football season
I find those C/N numbers curious, using commercial equipment we would have no chance to lock at 5.5db C/N. Link budget is usually around 17 db, with a fade margin of 5-6 db. When the operators uplink drops a few DB they get complaints from the villages on loss of video.Satbeams says 33.6 dBW signal in NM. If so, a 3m dish should receive. ARCS has a 5.5 dB C/N lock.
Added: Lyngsat says 40+dBW signal. If correct, should be receivable on a smaller C-band dish.
Sent from my SM-G950W using the SatelliteGuys app!
Limited time offer
