AMIKO - Amiko MINI HD265 - V1.5.63 Firmware with Muzak Radio Channels for SES 1 101.0W | SatelliteGuys.US
AMIKO Amiko MINI HD265 - V1.5.63 Firmware with Muzak Radio Channels for SES 1 101.0W
Hyper Casey
254
441
Mi
The 80+ Muzak Channels previously on SES 3 103.0W have permanently moved to SES 1 101.0W Ku Band. New location on SES 1 101.0W is TP 12000 V 20000 DVB-S FEC 1/2
These channels have "hidden" pids so they will not scan in on a blind scan on any receiver, they require manual entry one PID at a time, a daunting process for sure.
But good news, i have done the work for you. You are welcome!
The attached .abs file will load the Muzak channels for SES 1
This is for the Amiko MINI HD265 FTA Receiver Only!
Load using "All SW + bootloader"
Use at your own risk of course, and if you dont know what you are doing, please ask, and we can provide more instruction before you try to upgrade.
By loading this file, you will wipe out all of your channels. You will have to re-scan everything because some sats edited, and sat position numbers changed etc...
Back-up your existing Sat/TP/CH list just in case.
Casey
HyperMegaSat.com
P.S. After loading the file and after the receiver re-boots, go to
< Menu
< System
< Default Setting
< Save Default Value, Hit OK to Save
This will save the 101W Muzak channels as default, in case you want to start over the channel list at some point, these will not get wiped out.
