Amplifier Mount | SatelliteGuys.US
Amplifier Mount
daveh505@comcast.net
104
2
Las Cruces NM
I would like to mount my VHF/UHF signal amplifier on the antenna mast closer to the antenna. Does anyone know of a source for these mounts?
Picture to follow:
Thanks for the replies and answers. I have a preamp coming in place of the amp pictured.
That would be a preamp, not an amp. If you need a stronger signal that can better "survive" the loss going through a splitter, then it's a preamp you want.
daveh505@comcast.net, What your asking could be done with a small pelican or seahorse case the problem is those tin can 75ohm amplifiers are junk (in my opinion). All of the good 75ohm amplifiers have heavy metal cases and a low noise figure. There are other products out there that will do better.
Exactly how big is a "large directional" antenna?
Can anyone reccomend a good indoor antenna for digital TV signals?
