Hi, this my first post so be nice
I've had Dish Network since May '05 and for the most part it has worked great, except now for the last couple months... I've noticed two things that aren't too bad, but they get annoying at times.
The first thing is an audio related issue. This just started I'd say about a month ago. There is always a decently loud audio hum noise in the background of every channel. It is super noticable when there isn't much noise on the show. Oh and just to let you all know... I have two receivers (one upstairs and one downstairs) and they both are doing this. I was trying to figure out what caused this, and for both TVs I noticed it would chime in the hum whenever I plugged the video cable into the television (I have it hooked up via RCA downstairs and S-Video upstairs). If I just have the audio plugged in, I don't get the hum...? It used to never do this, so I emailed DN and they said I'd have to call. I figured I'd ask on here before going through all that customer service boredom.
The second issue is video related. This also started occuring just within the last month or two (I'm not really sure if they started at the same time or not though). I noticed at times I could see a horizontal line panning from the bottom of the screen to the top. It is usually only noticable on dark scenes, but it is at times noticable on lighter scenes. I tried adjusting the brightness on both of my TVs (yes, this is happening on both receivers as well) and I noticed when I made it really bright, I could very easily see a bright line panning that is I'd say about an inch thick. This too gets quite annoying.
I have really no idea what to try (it does this hooked up via coax as well) so if anybody knows anything I could try, I'd appreciate any help. If there's more info needed, please just say so and I'll post whatever.
Thanks in advanced,
Neal
Thanks in advanced,
Neal
