If you use the same account they transfer over. You don't need to buy them again.I have a question...can you run the Apps installed on your mobile phone on your tablet or do you have to buy them again? I would assume they would download/install since I would be using the same Gmail account.![]()
Anyone suggest any apps or stuff that would be good for a new android tablet owner?
I am getting one soon and would like some app suggestions.
It's going to depend heavily on your intended usage.
I have tools like vnc/rdp viewers, ash server, ssh clients, serial port tools, MS office alternatives etc.
I have some games and a print tool as well.
Short of VPN for work net access, I could use my Tablet for 95% of my work functionality. The last 5% is Visio and I cant find a substitute for it.
As someone mentioned, the Amazon free app of the day can be good stuff or not so good stuff. But definitely worth the daily check.
Use the same Gmail account for your Tablet and use your existing Amazon account for Tablet and phone and they will both have access to everything.
Sent from my MB855 using Tapatalk 2
Anyone use Words With Friends? I paid for the app on my phone and on my tablet it acts like I never paid for it and it show ads, plus it doesn't always show when its my turn.
Ramy,
I'll assume you are using the same gmail account on both your tablet and your phone. if you aren't, that is likely problem.
I wonder if the tablet version is considered a separate app from the phone version.
Limited time offer
