Anik F3 | SatelliteGuys.US
Anik F3
ZetaMale
17,326
13,125
USA
Is it just me or did the Univision mux go bye-bye? I can't get it off either dish and a re-scan turns up nothing.
I thought it moved to the mux on 87W (the other Fusion Media mux)
The one that had @Sports and the 2 Spanish channels?
found a post on it in regards to 87W....
Yes, the Fusion mux changed frequency and SR.
They added the channels that are in their Anik F3 mux.
I assume that the Anik F3 mux will go away.
So move to 87W and do a blind scan
Yep. It's there. Thanks. Also, I'm not able to pull in the Luken mux on SES2 - I think something was mentioned a long time ago in the Azbox forum about this but I never heard of a fix for this issue.
I'm using a 12 foot dish and all I get is choppy signals.
Anyway, I hope that this new location for the Univision stuff works out better. I had a hard time keeping my dish pointed at Anik F3. I guess I'll spend the bucks to get a pizza dish for the wife and hopefully there'll be less complaining.
DSR922 Battery Replacement questions
Gremlins and weird wonkiness
