Another EHD question | SatelliteGuys.US
inazsully
899
56
Sun City West, AZ
I'm sorry to ask a question that has probably been discussed but I just up graded to the Hopper from the 722 a few hours ago. I see how to transfer to and from the devices but unlike the 722 I don't see a way to watch something directly from the EHD. Am I missing something or does a program require transferring to the Hopper HD to view it?
With your EHD attached and running (after you've answered 'OK' to the USB Device prompt), press the DVR button, then up to the colored menu bar. Move over to the grey colored button with the name of your Hopper on it. Press select for a drop down menu that should include "External Device 1". Select that and you should see the recordings that are stored on the EHD. Watch them just like you would an internal recording.
Only on DISH
TV2 now showing as TV1?
