I have another question about the qph-031. Does it make any difference which port I connect to the motor? The linear or orbital, or no difference? Any input appreciated.
Iceberg said:either one works fine. Just make sure you are hooked to the L port![]()
Tron said:Whats really nice about this LNBF (the Invacom QPH-31) is that, since the linear side is standard (not universal), you can use a 4 x 4 22k multiswitch on it to give up to four receivers access to both polarities on both circular and linear satellites![]()
Limited time offer
