Another really stupid moment... | SatelliteGuys.US
mastermesh
1,988
just got my new motor up and running. From about 6:30 - 8:30ish this morning, I was trying and trying my darndest to get it all up and running with no luck at all. It was pretty cloudy, so I finally gave up about that time saying, Oh I'll mess with this all later when the sun is out... then by some oddball chance, I looked at my settings... DOH, my true south is IA6, not IA5!!!... Turned to the IRS channel and all of a sudden the signal showed up.
Since that time, I got it tweaked, tuned in to g10, and tweaked to get the weaker signals cranked up to around 30%... and off we go. IF YOUR TRUE SOUTH IS ONE OF THE IAs, BE SURE THAT YOU ARE TRYING TO PULL IN THE SIGNAL FROM THE CORRECT ONE! :)
I've had those moments.
Another one I had recently was I was trying to aim a fixed dish and I knew I was in the right area but couldn't get anything.
Then I looked closely at my settings and I had it set for 10600 22k on (for a Universal) and I had swapped to a standard LNB
D'OH!
I am glad when people take the time to post these types of issues. These are actually a mini troubleshooting guide. Thanks to all that share there simple mistakes.
In everything I do usually it is the simple problem, setting, human error that makes the difference between working and not.
BTW switch setting have gotten me already. When I took away my dishes pointing at dish/bev I had g10 on port 3 and changed it to port 1 and had no signal. Doh!.
Troubleshooting help needed
best setup for 4:2:2 with Twinhan 102G
