Antenna Help Ohio | SatelliteGuys.US
Antenna Help Ohio
mutex
I am ready to ditch cable TV. I will be moving to an apartment in Bellbrook, OH (45305) outside of Dayton. All the broadcast towers are around 10 miles from my location. Not sure of rules on an outside antenna, will an indoor one work to pickup all the channels?
I pick up a RS 15-1868 indoor antenna and i tried it out at a friends house that is also less than 10 miles from the towers and could not get any UHF channels. I will be getting a DTV converter box soon to test it further. Anything special you have to do to get UHF channels?
Thanks for any help
Thanks for any help
You should be fine. Hopefully you will be on the side of the building that faces the towers. A second story or higher apartment might help too.
antenna help (from a newbie)
Quality coax splitters
