Antenna help Please | SatelliteGuys.US
Antenna help Please
moverj
10
michigan
I Need help on the best OTA antenna for my area. I currently use a terk indoor antenna , and everytime I want to watch a different channel I have to move it to another room. I also tried a rca roof mount antenna with out much success. My zip code is 49341. Anyone have any suggestions. Thanks
you would need a combo vhf/uhf antenna
* yellow - uhf WTLJ-DT 54.1 IND MUSKEGON MI 245° 22.4 24
* yellow - uhf WXMI-DT 17.1 FOX GRAND RAPIDS MI 186° 29.8 19
* yellow - uhf WZZM-DT 13.1 ABC GRAND RAPIDS MI 309° 23.8 39
* green - vhf WOOD-DT 8.1 NBC GRAND RAPIDS MI 184° 29.8 7
* green - vhf WGVU-DT 35.1 PBS GRAND RAPIDS MI 245° 22.0 11
* green - vhf WWMT-DT 3.1 CBS KALAMAZOO MI 186° 33.6 2
suggest a winegard hd7082p antenna with a winegard hdp 269 preamp (if an amp is necessary), and rotor (since you have a 125 degree spead between towers).
Voom Sensar to DB2?
Did I damage my CM7777 ?? Also - a coax question
