antenna questions. | SatelliteGuys.US
antenna questions.
SMG
24
here is my info from antenna web:
now, im not really concerned about A and B, but i want the rest.
I tried this antenna from RS, and noticed no difference from no antenna at all. I mean zero difference whether hooked up, or disconnected. (looked at the signal strength on the HDTV receiver)
my question is, would i be better off with a directional, or omni?
seeing as C is a bit out of line.
i was hoping to try either of these:
http://www.affordablehdtv.com/wineg...Csid=73f43490074a76bea843b45ce9e0fd35&ref=100
http://www.lashen.com/vendors/winegard/uhf-vhf-fm_antennas.asp
are those worth a shot, or should i try something different?
i really wanted to try to buy something local to return it, incase it turns out to be crap.
eh, went down and bought a winegard 7005 at lunch.
we will see how it works.
ok, so the 7005 os the greatest antenna ever. well, at least that i have tried.
i immediatley got 44 with 80%, i added an amp, and it is at 90%
the rest of the channels flutter between 90 and 100%.
:eek: :up
interesting, but the 7005 was $30 and my amp was $20
I got a good deal
RCA DTC-210 needs an access card? What kind?
Anther antenna help request thread...
