antenna | SatelliteGuys.US
antenna
sloud74
34
Is there an option to install the antenna that voom supplies in an attic? Is the reception better outside vs in the attic?
I'm sure it will depend on your installer and if they want to climb up into an attic for an install as opposed to the roof. As far as reception, the roof should always be better then the attic. But depending on the channels in your area, the attic install may be quite adequate.
OTA Antenna choices, I need help badly
HD Net on OTA
