Any channel / software updates | SatelliteGuys.US
rv1pop
Since I am now using the advanced setup, I do not see the channel updates. Any thing new now or coming soon? It is after the first of a new month.
POP
Second, is there a new list of all the Glorystar co-ordinated channels - as in number order as you list them?
You may always view if new firmware and if a new channel list is available. Select OTA "UPDATE NOW" and press OK to view the current and latest firmware and channel data files. A few new channels will be added within the month.
A channel list is available at www.glorystar.tv/p/channels
What is the frequency and symbol rate of Glorystar OTA update channel?
I show the pid as 330 on my 1100c. Don't have a 200c hooked up at the house - can check at the office in the AM.
Two identical streams are currently running on Galaxy19 . 11842 as Bob mentioned and 12115. The PID is 330 on both. The 12115 OTA-SSU will be repurposed in late 2012.
Check the Signal Quality on the transponder for minimum 45 -50% Signal Quality.
Pid 330 helps!
Thanks for the PID 330. That did the trick. Got it updated.
All I know is the receiver lost the satellite, frequency, and pid for the OTA update.
It might have happened, when I turned the power switch off and back on.
After the update, I tried turning off the power switch, waited 30 seconds, and turned it back on.
Update remembered the proper satellite, frequency, and PID. So far so good.
DVR1100c Timer Won't Work for Scrambled Channels
No video on TP 6 today
