Just replace HDD to 500 GB and your 622 will have same storage as 722.
Ah, you're right. I shouldn't have said "my" since it's leased, don't really want to open it.
You can add and external Hard Drive, you don't have to replace the one in the receiver.
The next receiver models will likely be quad tuners or a hd dual tuner that can give hd signal to both tvs since they've pretty much done every other combination receiver. Also likely to come out with a dvr with more recording time.
Actually I think an MPEG4 8psk standard def receiver line is next. 311+, 322+, etc. I imagine they would be able to tune MPEG4 8psk HD channels and just downconvert them, so that DISH won't have to simulcast HD and SD channels on Eastern Arc or Western Arc. Then, when attrition cuts back the number of MPEG2 receivers to a point where a full swap out is feasible, thus enabling an all MPEG4 8psk lineup. All from three different LOS options for each site.
I was looking into updating one of my receivers and was curious if the 722 is going to be the best option out for a while or if there is anything new on the horizon that might be worth waiting on?
HD Dishonline.. imagine the possibilties!![]()
Won't happen anytim soon. There are too many of them out there. A 2700 is still usable.
Limited time offer
