I saw that but Randall posted this right under Scott's copy of the press release.I believe 11/19/08 was the date given on Tech chat, it isn't going to be there till they send it.
And Randall is usually reliable.The 211s are getting new software today.
Could be.I was gonna say, L522 is spooling to some 211 receivers as of yesterday. I would think that this software update will enable the EHD feature.
L522As of a couple of hours ago I still have L453.
FYI the 211-not k is on a different, higher number. L520, I believe.
OK in order.If you could just monitor Randall's thread (new SW) and wait when new FW for your ViP211k begin spooling, then the thread would have some meaning.
Plus they told yea - November 19; who could tell you if it support EHD or not, if Dish cannot activate it for you.
Thread about nothing, hehe.![]()
Try it this way: Someday someone will get a new version of software for their 211k and they will see that if they plug in an EHD they will see a message to call Dish to get it activated.OK, but you asking for unknown version, plus want see exactly EHD support type and before ppl could activate it - chicken or egg, right ?
I would connect any USB disk enclose to 211 if there L5.22, just to check if that popup window could appear.For cheapness if you already have a 211 all you'd need to do is buy a drive (could be under 100 bucks) and pay the 40 clams.
There is no monthly charge and no requirement to connect to the net or a phone line.
One thing: Since the drive is the DVR you can't send movies or shows to "archive" like you can by adding a drive to a 722.
But... You can buy more than one drive for which Dish doesn't charge you any additional fees. It would just be slightly odd to have "archives" that are totally in date sequence.
Anything's possible but it was mentioned a few places that the 211k was going to get enabled before 211 not k's were.I would connect any USB disk enclose to 211 if there L5.22, just to check if that popup window could appear.
Weird... my 211 downloaded L521 yesterday. There's a L522???
The SD 144 is there but still no HD video!
Call Dish tech support. Supposedly this is why 523 was issued to replace problems with 522.
Im still showing 521 on my 211.
BTW-- are you seeing the 9 day guide?
Limited time offer
