Any PCI cards for C band FTA? | SatelliteGuys.US
I have an analog receiver, no problem there. Is there one that is confirmed to do HD without some add on chip?
We have a whole department here in the forum, devoted to DVB cards on your computer:
Free to Air PC DVB Discussion - SatelliteGuys.US
What may not get discussed too much over there, is the use of the Vboxes or Gboxes to move your dish, nor how to move a co-rotor.
But since you have an analog receiver for those tasks, you're covered. - :up
The output signal from Ku-band and C-band LNB is the same, so a PCI card or USB box doesn't really know nor care which band it's on.
Most DVB-S cards can do HD, but to do the S2, you'd need a DVB-S2 card (or USB box).
Both can be Standard Def, or Hi Def.
Antenna positioner interface?
Best Brand Splitter?
