Any solution to get C/KU Circular and C/KU Liner using a single dish? | SatelliteGuys.US
The easiest and least expensive way would be to place an offset C-band LNBF with Dielectric insert and also an offset KU-band circular LNBF. You could build a Frankenstein single feedhorn with multiple wave guides, but the mechanicals would probably induce similar losses as an offset.
A Chaparral Corotor II Plus International Wideband Feedhorn with C/KU LNBS will work.on one dish
FREE DBS???
ID this dish
