I'm looking at putting a dish for PBS HD any suggestions on a receiver that works well for this. Also what units will work for the CW HD feeds would be nice to know also.
Digiwave Diamond does HD and DVB-S2 ....
So are the Diamond 9000HD and the Viewsat 9000HD the same unit just under different names? I see more of the Viewsat available than the Diamond.
Wound up getting the Coolsat 8100 HD for really inexpensive off ebay. Is there a way to get it to use a larger ext HDD? Will also ask this in a new thread. Noobie to FTA not to sat or PC.
good luck
no AC3 on those coolsats i hear.
What about with external decoder?
i would think so, use them on my old SD boxes.
but the bulit in's work much better.
edit
30" Star Choice dish on G10R(have to decide on new assignment),
took mine to 105 it was weak on my motors now it booms lol
good luck
I was thinking more like if you had a home theater receiver with optical input. That is what I use for audio from my Pansat 3500. Just started looking around for a good deal on a HD FTA receiver. Seems that people are still trying to get a good buck for them even if they have hackware on them.
The 8100 will output AC-3 through the HDMI, optical or rca cables. no extra equipment needed
Used the 8000 (8100 - a PVR option) for lots of AC-3 programs. works great
Limited time offer
