Any way to convert old UHF remotes to IR? | SatelliteGuys.US
Mr Tony
3,369
14,794
Mankato, MN
I'm trying to figure out something for my dad who has a 625. (yeah I know....he doesn't want to upgrade. He owns all his equipment and has since day 1)
His TV1 remote looks like hell with buttons wore off and it just looks scuzzy. So I happen to find in my box of junk 2 UHF (TV2) remotes. So I know they will work right now only on TV2
Any way to turn them into a IR remote so I can replace the existing one?
One is a 8.0 UHF PRO and the other is a 6.4 IR/UHF PRO
They should output an IR signal without doing anything except setting the correct address for TV1
Edit time the 8.0 needs a green #1 tab to switch to IR. I don't have a 6.4 so it's back to searching..
6.4 also has a green I/R and blue 2UHF tab you probably have a silver UHF tab.
tried that already and it didnt work.
the 8.0 has a silver "tab" at the bottom
The 6.4 has a blue TV2 at the bottom
oh well....back to searching in the junk boxes :)
If you open the battery case the 6.4 blue tv2 tab should be green on the reverse side. Flip it over to the green tv1 side press system info on the rcvr and press record. It should change the remote address.
when I pull out that tab (just figured out how to do that) ;) the other side is black
will have to try that when I get to my dads
also I noticed on the 6.4 remote there is a A/B switch on the side of the batteries. What does that do?
I was going to suggest that, or I'm thinking Remote Channel 1 on the receiver will work with any of the remotes?
take note of the groove positions.
Reactions: Mr Tony
Put it on the black side and program address. Should deactivate UHF and be able to control as TV1. That's what I did here.
Reactions: Mr Tony
After switching around the keys, don't forget to push menu twice in the front receiver buttons and then push record on the remote to pair the remote with the receiver.
netflix app question
ESPN 2 HD ?
