Any way to make remote jump directly to multiple favorites? | SatelliteGuys.US
mgh
26
I know that you can scroll through the favorites listing then choose one and jump to it, but I really like my cable's favorite set up. You can jump directly through all your favorite selections seeing each as you go. Can it be done on Voom?
If you have the single line Surf Bar displayed you can press one of the colored buttons and it will advance to your next Favorite, is this what you mean?
But it doesn't take you directly to the channel until you press ok or enter whatever.(not at home now). I'd like to go directly to the next picture without having to do that.
Gotchya now! They need to implement Favorites like Dish does, that way when you channel up/down, you are channeling through the Favs list that you have currently selected.
Possible STB OTA problem with 6.2 ????
VCR+ codes for voom programming?
