Anybody having trouble logging into Directv.com account | SatelliteGuys.US
Same here. Have been trying several times today using Safari, Chrome, Firefox, Edge, and Brave. None works. Get the same error as you...bad request. Same thing on both Windows and Mac.
was able to log in just now using edge with no issues
I just tried it and had no problem.
Are your DIRECTV accounts at att.com or directv.com?
Mine is at directv.com and after giving it the username and password I get this:
Also tried deleting DIRECTV cookies and that didn't help.
I have not experienced any issues in that regard. But on a separate note, signing into the Max app via my DIRECTV account and equipment has been a no go for awhile now. This issue began shortly after the conclusion of The Penguin limited series first time broadcasts. This issue has still yet to be resolved, at the current time. Hopefully, the Engineering Depts. at DIRECTV and Max can find a way to get this issue taken care of asap.
Unless something has changed recently you don’t login to MAX with your DIRECTV account. You login with your MAX account and then set DIRECTV as your TV provider.
I was also unable to log into Max ...The APP.
I did get Max thru YTTV and it works fine, I just have to remember to use that route and not the Max App.
Sorry for the late reply, As of a few weeks ago, my account is now at Directv.com. The account was removed from ATT.com in the past few weeks. Perhaps other account migrations contributed to the problem.
Reactions: John2021
Sounds feasible to me if they are in the process of moving people over.
I tried logging into my acct last night using edge and chrome and it would log me right back out
We were told it's because our dtv is still bundled with att. Who knows
When I check my account, the login is at att.com and the overview page is at directv.com. Has the switch already happened for me?
Yes. My account is at directv.com but when I click sign on it goes to the login at att.com and after logging back in it redirects back to directv.com. Once AT&T is out of the picture and all accounts are back at DIRECTV they should switch the login over to just directv.com.
Reactions: lordodogg
