Anyone able to get this on G26? | SatelliteGuys.US
schnitz411
45
Has anyone ever gotten CBS feeds on Galaxy 26?
I get all sorts of other news (fox mostly) 12048-12132 range all the time with a 90% quality signal but never seem to abel to get CBS feeds in the 11710-11820 range. For example there is stuff from the NYC crane accident right now apparently on 11777.125 V 3979 but I can't see it
11777.125
V
I'm pretty sure I'm aimed well since I get other things from that bird, but missing something apparently? Not even a scrambled signal. Just nothing.
Using Coolsat 7100.
Ideas?
Can't express enough thanks for guidance as I figure out this stuff as a newbie.
I'm seeing the 11777/V/3979 crane coverage just fine. My channel is labelled DC Path2, for what THAT is worth. Coverage also on CBS Newspath , 11710 /V/ 14328 .
Bring up the transponder in question on your antenna settings menu, and check the quality level.
Hmmm...
No dice for me still.
I deleted all my transponders/frequencies on the bird below 12000. Did a totally new blind scan for everything up to 12000. (Coolsat 7100).
Found 11722 H 3978 (actually it is appearing as V also) which is labelled as WCBS Digi KU and matches up as "2A" in CBS nomenclature, exactly where it should be.
But I am not finiding the Newspath feed anywhere which you guys indicate is on 11710 (or close thereto according to toher people). I know I'm on the bird because I am seeing other stuff that is suppopsed to be there and I thought deleting everything in that range would clear out any bad PIDs or whatnot, but apparently not. Any thoughts on what the problem could be?
still getting various feeds in teh 12000+ area (Fox territory).
Coolsat 7100, dish pointing by 4dtv.
Set for standard LNB.
AMC6 on a 18" dish
Fortec Star firmware update
