Anyone Having trouble with the program guide | SatelliteGuys.US
vodad
269
Mine is showing no info available on a lot of channels, both my 622 and 625, and the DVR on the 622 is recording half hour shows for 3-4 hours.
No troubles here. Try a re-boot followed by a check switch (make sure to re-test). When finished it will download your guide. If you are having problems with two receivers and you still don't get the program info, you either have a bad switch or dish is out of alignment. Good luck.
something cleared it up last night, it had been going on for 3 days. but all seems fine now.
tried all those suggestions and nothing helped.
OTA vs. Sat HD Local
