Anyone having troubles with...... | SatelliteGuys.US
  • Thread starter Thread starter n1wbd
  • Start date Start date
  • Replies Replies 0
  • Views Views 882
n1wbd
Silent Key - RIP 1/2/2012
826
Grafton,NH
Their VIP222 receiver, during the last approx 2 weeks I have had to RESET my receiver 5 times. It shows up when the receiver has been Shut off with the remote then later when you try to hit the select button to turn it on you get no response. Also pressing and holding the front power button has no effect you have to unplug the unit and plug it back in after 10 seconds or so. The problem shows up intermittently. The current software in it is L3.06. I called Dish and all they did was to fill out a "trouble ticket" and said they will send the info to senior techs and they'll get back to me. We shall see. Note after resetting receiver it seems to work fine no notable problems chnging channels etc.
Bob
How to get rid of the Lease Fee on HD recievers?
AEP and Ultimate vs Absolute
