Anyone in Washington State having audio problems on KOMO? | SatelliteGuys.US
Hi Ho
19
I have some very annoying problems with KOMO HD through Dish Network. The audio stutters and sounds like a dirty CD. When this happens, the Dolby Digital symbol on my receiver flickers. The problem is especially prevalent on ABC News programs and it happens every day. The audio is also horribly out of sync.
Has anyone else noticed this problem? I emailed KOMO and they kindly responded with some possible causes. They said that Dish receives their signal OTA and that could be where the problem is introduced. If that is the case then others must be experiencing it as well. Anyone?
I wanted to ask you if you have a DVR, if you pause the broadcast the resume after a couple of seconds, does the problem still exist? Also, what tuner do you have?
Upgrading dish 500 to dish pro
external hard drive for vip 211k
