Anyone ordered from them? | SatelliteGuys.US
hometheaterman
604
I was looking at a reciever from UMG_Sales on eBay and was wondering if anyone has ordered from them? It is a refurbished reciever and says it has a 1 year warrenty. I was thinking I had heard of this company before but not sure. If I have problems would the warrenty be through Dish Network or them? Should I ask for the S & R #'s or would it be clean? They have mostly positive feedback so I would think they would be good guys. I wish I had ordred it from DishDepot but they no longer have what I want.
Hi HTM,
some weeks ago, I bought a 921 at e-bay. I asked for the 2 numbers you mentioned and after I had them I called dish. They will tell you right away , if it is clear of any depth. I felt comfortable afterwards, bid on it and got it.
Hope it helps and g'd luck!
Matt :)
Remanufactured receivers are warranted by DISH for 90 days. You can always buy the DHPP for $5.99/mo. You could also call DISH and see what it will cost you to buy directly from them.
Card Swap Channel List
How long before I see Club Dish credit?
