Anyone See A Problem With.... | SatelliteGuys.US
cooper
106
Long Island, NY
running the lines from my two E* sats down from my roof through the leaders and gutters and into a hole in my foundation? I'm having my house resided and would sure like to hide all those wires (6 of them-still legacy not dishpro yet). Currently they're strapped to those same leaders and gutters using wire ties.
Thanks in advance.
Coop
The problems I see are future service of those cables if they are hidden under new siding. There is always the possibility of a nail being driven in to a cable while putting up the siding.
They won't be under the siding. I just want to pull them through the leaders and lay them in the gutters like a conduit.
As long as they're "flooded" cables you shouldn't have a problem. If they aren't rated for direct burial (basically what it would be inside a gutter with water and leaves, etc), you could have problems later on. You could go buy actual PVC conduit for about a buck and a quarter per joint and have a pretty tidy install.
Diplexor, Sat sig fails with antenna
