FOR SALE - Anyone want a 4K 4x4 HDMI Matrix/Switcher | SatelliteGuys.US
FOR SALE Anyone want a 4K 4x4 HDMI Matrix/Switcher
  • Thread starter Thread starter cpalmer2k
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
cpalmer2k
1,079
677
United States
I bought this for my "man cave" earlier in the summer but ended up not needing it. Paid $139.99 on Amazon, will sell for $125 shipped to your door. Here is their description. Still brand new, sealed in the box.
sdfgsdfg
matrix 4 in 4 out hdmi switcher with remote 4K Ultra HD UHD HDCP 2.2 3D 60hz multiple source
gofanco 4x4 HDMI Matrix 4K 30Hz​
Allows you to connect up to four HDMI source devices and independently distribute any source to any of the four HDMI displays. Easily switch between the four sources onto any of the four connected displays. Choose to have the same content on all displays or different content on each display! - Made in Taiwan
hdmi matrix 4x4 seamless switch between four sources four outputs 4k 30hz UHD remote control IR
Cost Effective 4x4 HDMI Matrix​
Features​
  • Supports HDMI 1.4 & HDCP 2.2
  • Supports resolutions: Up to 4K @60Hz 4:2:0, 4K @30Hz, and 1080p 3D video
  • Supports DTS-HD, Dolby TrueHD, 7.1ch digital audio and all other HDMI standard formats
  • Smart EDID management allows for automatic facilitation of format control between source and display to ensure high quality video
  • Firmware upgradeable for expanded compatibility through mini USB or RS-232
Excellent A/V Distribution Solution​
HDMI signal routing in environments where multiple AV sources must be shared in 4 different zone or displays, to reduce the installed equipment clutter and to reduce the costs involved with multiple, redundant devices.
Note about resolution​
If you plan to use for 4K 60Hz, it MUST be in 4:2:0 chroma subsampling (not 4:4:4 or 4:2:2).
Recommend only to use for 4K 30Hz, if you aren't sure what this means.
Multiple Switching Options​
  • Front Panel Push Buttons
  • Local IR Remote Control
  • RS-232 Control
Friendly Reminders​
  • Does not support 4K @60Hz Chroma 4:4:4 or HDR. 4K/60Hz 4:4:4 input devices will be downgraded to 1080p output.
  • Please use High Speed HDMI cables when transmitting 4K content.
Specifications​
  • Video resolutions: Up to 4K @60Hz 4:2:0, 4K @30Hz, and 1080p 3D video
  • HDMI 1.4, HDCP 2.2
  • HDMI AUDIO - Supports DTS-HD, Dolby TrueHD, 7.1ch digital audio and all other HDMI standard formats
  • Housing: Surface mountable metal enclosure
  • Country of origin: China
  • Regulatory approvals: FCC, CE, RoHS
Compatible Devices​
  • HDMI source device, such as computer PCs, Blu-ray players, game consoles, and media players
  • HDMI displays, monitors, HDTVs, XBOX One S, PS3/PS4, Amazon Fire TV Cube, Apple TV, Roku, DVD or BlueRay Player, Satellite Box, Cable Box, Android Box, and more!
What's in the Package​
  • 4x4 HDMI Matrix 4K
  • IR extension cable
  • IR remote control
  • Power adapter
  • Housing rubber pads
  • RS-232 cable
  • User’s guide
