Anything on Galaxy 13 | SatelliteGuys.US
Morbius
344
6
N.E. Ohio
Finally got 5 big pines cut down ,so I can get G10 all year instead of waiting for the leaves to fall from the maples. Anyway I got the dish "slapped" up trying to get G10 before the rain came again ,but had to stop after getting G13. Is there any FTA there other than music? Also in inches how far away will G10 be from G13.
Mike
G13 is a smidge (less than 1/8" if you put a mark on the mast)
One ethnic channel. The rest is scrambled
That was the answer i was hoping for. The afore mentioned maple is about 10' to the right ,so i should be in good shape. Also Brett Farve needs to retire.
There are some Chinese channels on G13 @ 127.0w, it's H1 for ku, don't know about any music channels there. I think you mean IA13 @ 121.0w, and the music channels are on E*9 actually.
Al
Al, I think you are correct about that. Either case im in the neighborhood of G10. Now the maple may be a problem.
Can't do IA5 - what about G10?
WVXF or WVGN on Galaxy 16
