Anyway to save favortites permanently? | SatelliteGuys.US
Diamond Dog
29
I like the "show subbed channels only" option while using favorites.
However, when I turn the receiver off and back on again it reverts back to "show all channels" again.
This happens even though I select "save" when I select "show subbed" option
Is there a way to make the show subbed option stay?
I believe that is another software bug, along with the ability to save only 120 channels in your favorite lists. I have a 301 and that along with other problems are very noticable with the 811.
Don't know if it will ever be fixed, but I do know my 301's don't do that!
On my 522, you just hit 'Guide' repeatedly and it'll scroll through the favorites lists. For instance, you hit Guide 4 times to get to my favorites list - first All Chan, then All Sub, then my wife's, then mine...
After you turn it off, or even reboot, you can just hit guide a few times to get to the correct one.
What *I* don't like is having to set 2 different favorites - one for the tuner 1, and another for tuner 2. Why can't they work on both TV's!?
Bizzach said:
... What *I* don't like is having to set 2 different favorites - one for the tuner 1, and another for tuner 2. Why can't they work on both TV's!?
I agree - if it's a User selectable option.
After all, how many x22 boxes are "shared" between the parent's bedroom and the kid's. Gotta have separate lists there.
721 Weird Video Problem
Team Summit Video NOW ONLINE!
