Archiving from DVR 522 to VCR/DVDR: Batch? Realtime? | SatelliteGuys.US
Kilt
4
I am a cable customer with a Panasonic E80 hard drive DVD recorder who is considering moving to E* and a DVR 522.
My goal is to have certain sports programs end up on my E80 hard drive (for archiving to disk) after passing through the 522 for decoding, all in the most time-efficient manner possible. The same issues present themselves whether the archiving device is a DVD recorder or a VCR, so I will just call the archiving device the "DVD/VCR". I have not been able to find an in-depth treatment of the related issues with respect to the DVR 522.
My terminology may be incorrect, but I want to explore whether "batch" and/or "realtime" transfers from the 522 to a DVD/VCR are possible; and, if possible, how they are affected by pauses and replays. By "batch" I mean a transfer that happens at some LATER time, after the program has already been recorded on the 522's hard drive. For example, you record a game on the 522 today and batch transfer it to the DVD/VCR tomorrow. By "realtime" I mean a transfer of the game from the 522 to the DVD/VCR at the SAME TIME it is recording onto the 522. That is, in one recording session you simultaneously record the game on the 522 and the DVD/VCR.
The procedure I would much prefer for the subset of games I want to archive is a realtime transfer. I realize that realtime transfers from the 522, if otherwise possible, will require the DVD/VCR's timers to be coordinated with the 522's recording session.
Questions arise as to batch and realtime transfers when I look at a picture of the back of the 522, and as I try to understand how the 522's dual-tuner/dual-TV concept is implemented.
The 522's output connections are organized as TV1 connections and TV2 connections. The TV1 outputs are: one trio of composite connections, one S-video, and one coax cable. The TV2 outputs are: one trio of composites and one coax.
Surely you should be able to batch transfer a recorded program from one or more of these 522 outputs to a DVD/VCR, but implementation and cabling questions arise. The first 4 questions relate to BATCH transfer capability:
1. Can you batch transfer to the DVD/VCR via the:
(a) TV1 composites?
(b) TV1 composite audio + S-video?
(c) TV1 coax?
(d) TV2 composites?
(e) TV2 coax?
2. This seems self-evident, but if the 522 is connected to TV1 via the one and only S-video port, then you cannot connect the 522 to the DVD/VCR via S-video, right?
3. If you can transfer via the TV1 and/or TV2 coax outputs, do you lose the ability to have stereo sound recorded into the program copy on the DVD/VCR? Or can a stereo DVD/VCR still separate the stereo signals and send them to a TV via composite cables?
4. If batch transfers are doable, can you set up the transfer so that multiple programs (an actual batch) are transferred from the 522 without further human intervention, or is it only doable one program at a time?
The next two questions relate to my preferred procedure of REALTIME transfers. Assume the 522 connects to TV1 via the composite audio and S-video. What I would like to do is: watch a basketball game on channel 777 on TV1; do a bunch pauses, replays, etc. as I am watching; and end up with an un-paused, un-replayed, clean copy of the game on the 522 (which should go without saying) AND also on the DVD/VCR.
5. While the game is recording onto the 522, can I simultaneously have it outputting in realtime from the 522 to the DVD/VCR via the:
(a) TV1 coax?
(b) TV2 composites?
(c) TV2 coax?
6. If I can do a realtime transfer via any or all of these outputs, what effect will pauses, replays, etc. have on the copy of the game recorded on the DVD/VCR? Because of the 522's unique TV1-TV2 tuner and output duality, I'm wondering if the answer to this question depends on whether the game is transferred via a TV1 output versus a TV2 output.
More specifically, does the 522 work this way: The game is recorded from channel 777 via tuner 1 to TV1. All the pauses and replay's appearing on TV1 relate (only) to this tuner 1 activity. Hence, if a realtime transfer can be made from a TV1 output, the pauses and replays will be recorded onto the DVD/VCR. If, however, you CAN realtime transfer via the TV2 composites and/or coax, can you tune the DVD/VCR to channel 777 via tuner 2, just as if the DVD/VCR were an actual TV2. If so, wouldn't the channel 777 game being sent to the DVD/VCR via tuner 2 be separate and immune from the pausing and replaying activity taking place on TV1-tuner1, which just happens to be receiving and recording the very same channel 777 onto the 522? Hence resulting in a clean copy of the game on the DVD/VCR (assuming no pausing, etc. on TV2-tuner 2 via the TV2 remote)? Or are my speculations all or partially wrong?
I can't figure out the answers to these questions and neither can the E* sales reps. But the answers are crucial to my decision as to whether I switch from cable or not. I'm hoping some of you technically knowledgeable 522 owners can provide answers.
Finally, my understanding thus far is that the D* Direct-Tivo can do both batch transfers and realtime transfers, but that pauses and replays during realtime transfers will be recorded on the DVD/VCR. Confirmations or refutations re Direct-Tivo would also be appreciated.
Welcome aboard Kilt! :)
My, you have a lot of questions. I think you're just wanting some confirmation of what you already know.
In summary. The 522 has no idea what it's "talking to". It can output 2 shows - same or different, live or recorded. Think of it as two separate units that share a hard drive.
A1: Yes.
A2: There ARE S-Video splitters out there. Dunno more than that.
A3: The TV2 coax output is in MTS (standard) stereo. The TV1 output is NOT.
A4: No.
A5: Yes.
A6: One output can be feeding the DVD burner 'live' while the other is you watching it and pausing, replaying, whatever - no effect on the other output! TV1 vs. TV2 is not an issue - except for the S-Video vs. coax stereo (see A3).
Your scenario paragraph after Q6 is correct - remember think of it as 2 separate boxes sharing the same HDD. New scenario: You're not even home for the game which is now recorded on the disk - from EITHER tuner (ie. the wife was watching something else while the game was on :) ). Now, it's your turn to watch - and pause and replay. Meanwhile, the other output is just dumping to DVD. OR, wifey is using another TV and watching something else - live or recorded, and you'll dump to DVD while you both sleep. ;)
Hopefully this has given you the idea that the box (barring bugs!!!) has the functions you need - the hard part is which hookups to what, and you're probably up to speed on that. :)
Simple Simon,
Thank you for taking the time to read and respond to my post.
Don't be fooled into thinking that I "know" anything just because I have a Tolstoy-like ability to write 100,000 words to ask a simple question. I knew a techie, a techie was a friend of mine, but I'm no techie. I was seeking confirmation of some tentative conclusions I had reached after a lot of internet reading and cerebral struggling.
I'm happy that the 522 can do the tasks I'd hoped. But I'm still a little confused by your statement that "TV1 vs. TV2 is not an issue" after you had essentially agreed with my scenario. When you say "other output" in your "new scenario" I take it that you are saying this: If you are watching, pausing and replaying the game on TV-X, you can dump a clean and uninterrupted copy of the game to the DVD/VCR from the outputs of, and only of, TV-NotX.
Can you dump an uninterrupted copy from any of the 721 outputs if you were pausing and replaying during the dump? I'm hoping the answer is no, if only to credit the 522 with a capability possibly not possessed by any other DVR.
Oh, yeah ... barring bugs. :)
You've got it. And you're right - the 721 can NOT do it - it only has a single output (several forms - RCA, RF, etc. - but all the same content). 522 has 2 independent outputs, therefore, A-OK.
What I do when making a recording of my F1 races is watch TV1 while having my computer hooked up to TV2 (tuned to the same channel, or another one) to record what I'm watching right now. That way, if I pause, it doesn't affect my recording..
When recording something off of the 522's hard drive, I don't do anything else, since as of 2.01, it seems that if you burden the system too much, you will get A/V glitches... I've ruined a few recordings that way.
Wishbone,
What you are doing with the races is exactly what I would want to do with basketball games, except I would be connecting my DVD recorder to TV2 where you connect your computer.
Do you use 522 single or dual mode when you watch and record this way?
Do you use the TV2 composite or cable outputs and notice any difference between the two?
I use the composite outputs... For some reason, the cable output looks really crappy.. I don't know if it's the TV or the 522.
(a) TV1 composites?
(c) TV1 coax?
(d) TV2 composites?
(e) TV2 coax?
(a) TV1 coax?
(b) TV2 composites?
(c) TV2 coax?
Did it work? Were uable to batch and realtime to DVD recorder?
Thanks,
Beba(ELizabeth)
Having to cancel Dish, I'm not happy
Dish 625/522 question
