Archos 605 wifi/722 recording issues | SatelliteGuys.US
stugots48
29
I cannot seem to record shows using the DVR station attached to a 722. When I set a recording using the archos tv guide it records from the wrong tuner on the 722 or if it is in the middle of the night it records the screeensaver from the 722. Is there a secret to recording from the 722 or should I just be happy transferring shows and never watch a HBO show on my 605 since it won't transfer due to copyright protection?
Congratulations. You hooked your DVR Station into the wrong 722 tuner output. Since the DVR Station has an IR-blaster, and since that only works on TV1, you have to plug it into the TV1 output. (This is all theoretical since I don't own a 722 or a 605!)
WB 39 HD in Houston area!
DishNetwork in Mexico?
