From what I saw the DTV 32 works with Dish and Directv. So not really sure what your asking.that is totally wrong, the dtv32+ is used on Directv dishes all the time. i have never seen a dtv32+ on a dish network system, i suppose it could be used on a legacy or fta, but generally it is for directv. Anyone else have an informed answer?
2 seconds of a google research by the way.that is totally wrong, the dtv32+ is used on Directv dishes all the time. i have never seen a dtv32+ on a dish network system, i suppose it could be used on a legacy or fta, but generally it is for directv. Anyone else have an informed answer?
And thats Totally wrong.the dtv32+ is used on Directv dishes all the time. ?
What are you interchanging.how does that answer my question to whether those lnb's are interchangable?
Yes for Directv, But from what I saw the 18 won't work with Dishnetwork.a simple google search would find your answer
They are pretty much the same and will work on a single LNB setup (101)
Which is why I'm guessing they don't list it as working with Dish Network .The 18 is a dual LNB that would work for Dish in a legacy setup
Maybe if the OP would have giving maybe a hint on what the application was, instead of a half a sentence. Cause the answer is not a Cut and dry Yes or a No with the Dish equipment.but it will work with Dish....its just grossly outdated
Limited time offer
